We've had a lot of these kinds of threads lately, so there's already a lot of good information on these forums for you to look at.ndruw said:where would be a good place to find beginners tutorials/how did you first learn to program?
as far as learning the basics of programming and data structures, nothing beats ADA, in my opinion. ada is sytactically friendly and also very friendly to the programmer learning data structres due to the large amount of run-time checking that occurs. Java is good, too... but it isn't as friendly with the syntax.
i would completely avoid c++ until you understand a basic level of computer architecture and assembly programming... c/c++ are very much like programming in assembly, only less tedious. anybody who knows architecture would agree at least somewhat.
in summary, ada has friendly syntax. it also helps the beginning programmer with run-time checks.
java is not as friendly as ada, but provides more detailed run-time checks. it is kind of difficult to learn right away because of it's deeply OOP nature. it can be considered a middle ground between ada and c/c++.. java also has *THE* best documentation of the three langauges.
c++ is a fun language, quick to code in, but difficult to track down mistakes at times. it also lacks certain abilities that the beginner will aprreciate such as string slicing.
all three languages are free. you can find ide's/compilers on the web..
mikeblas said:It worked! It worked!!! Someone quoted me and I don't have to type my stock reply all over again! It worked!!1!
Dock my pay? You should give me a raise, since I'm working smarter and not harder.nameless_centurian said:i hope that doesn't mean you'll be taking the evening off. we'll have to dock your pay.
