Hi All,
I recently built a system using the following :
1) Silverstone TJ-08 MATX tower Case
2) Biostar TForce6100-939 Motherboard
3) XFX 7900GT Extreme Video Card
4) A Sound Blaster Audigy 2 ZS
5) Belkin Pre-N Desktop Card
6) Seasonic 430 Watt Power Supply
My problem is this :
A) The system seems quite loud primarily the video card
B) The video card temps are really high (62 degrees) at idle and I am worried about the card itself and the other two immediately below it
In light of the above I want to try watercooling the CPU and GPU primarily the GPU though. I have never done anything like this before and have been looking around this forum for answers. I have the following constraints on any setup :
I) The system should be quiet.
II) The GPU water block has to be single slot given the other cards in the system
III) The pump sub-system has to turn on when I push the power button (hence I imagine a 12V pump is in order). ( Can the PS above power this ?)
IV) The entire system should be housed in the case (silverstone TJ-08)
Is all this possible on a $100-$150 budget ?
Any advice / suggestions most welcome.
Best Regards,
Caspanis
Best Regards,
Caspanis
