HDBox2d1 said:D. Light told me it does not matter that much.
If you are wanting to hotswap,you HAVE to use SATA Power.. Correct?
There is also another reason.. gonna edit it in,.
TeeJayHoward said:If you have the SATA power connectors, use em. It's not like they're going to be used anywhere else!
DougLite said:Either or, not both.
Yup, that's okay. Just never plug both SATA power and the molex connector in to the same drive. There's bad things and a very good chance of some pretty smoke.HDBox2d1 said:I Have a 36GB Raptor and the WD2500KS.
The raptor is connected via SATA Power and the WD2500KS is connected Molex.
Is this ok?
Thanks
TeeJayHoward said:Yup, that's okay. Just never plug both SATA power and the molex connector in to the same drive. There's bad things and a very good chance of some pretty smoke.
rodsfree said:
I'd like to expand on this a bit if I may. Are these latest (Western Digital in this case) SATA2 drives backwards compatable with an SATA150 mobo interface?DougLite said:Either or, not both.
As said earlier, the SATA connector is required for hot swap. They function identically otherwise for current drives - delivering +5 and +12. In the future, the SATA connector may be required for some drives, as SATA connectors also supply +3.3, which a regular Molex cannot do.
WD and Hitachi are the only SATA drive makers that provide for Molexes. Seagate, Maxtor, and Samsung do not.
