Hi guys...I couldn't find the right place for this so I'll just post it here...
This happened for the first time and it's my first time to see something like this :S
Before we go on, my setup in my sig, everything stock except for the CPU is overclocked(3.8GHz @ 1.55V), I ran an 8 HOURS stability test, and it was 100% stable...And I've been running this CPU at that clock for more than a month now and this happened for the first time now :/(CPU was running fine at that clock for over a month)...
I only OC it up to 3.8GHz when I game which I do like for 2-3 hours maximumly a day...And if the PC is running the rest of the time it's downclocked to 0.800MHz.
Temps were fine at the time of the crash(52c)...
Here's a screenie:
If any of you guys know anything about this...A fix, or what's wrong...Will always be appreciated.
Thanks in advance
EDIT: I forgot to add that it would stay like that forever, it won't restart on itself like it would on some other situations, I had to hit the restart button on the case.
EDIT #2: I'm not facing any problems now, I'm just curious what made that happen.
Tj
Here's a screenie:
Thanks in advance
Tj
