So, my 7200.11 1.5Ttb was failing and I tried to RMA it with Seagate. That was a month ago. They sent me a 2tb Constellation drive, which was about 50% bad blocks, per chkdsk. I talked to seagate and they sent me a 2nd 2tb Constellation which failed to even spin up. I sent both those back and today a 7200.11 1.5tb arrived, which I immediately tested, and it also has a huge number of bad blocks.
But I noticed something curious in the number of bad blocks of the 2 drives that worked. According to my chkdsk attempts, they both had 1073GB of "good" blocks. Is it possible that there's some compatibility issue with the PC I'm testing them with (an old Sata 1 intel D865GLV mobo), such that blocks above 1TB are detected as "bad" and so marked? I had no such problems with the original 7200.11 1.5tb on this machine, though. Maybe the newer drive firmware is incompatible?
Replacement #1 (Contellation 2tb):
Replacement #3 (7100.11 1.5tb):
The "good" block counts aren't exactly the same, but they're similar enough to wonderWTF !??
1953512000 KB total disk space.
0 KB in 1 files.
4 KB in 9 indexes.
879764200 KB in bad sectors.
125604 KB in use by the system.
65536 KB occupied by the log file.
1073622192 KB available on disk.
4096 bytes in each allocation unit.
488378000 total allocation units on disk.
268405548 allocation units available on disk.
1465136000 KB total disk space.
0 KB in 1 files.
4 KB in 9 indexes.
391370848 KB in bad sectors.
110700 KB in use by the system.
1073654448 KB available on disk.
366284000 total allocation units on disk.
268413612 allocation units available on disk.
