tuksonrider
- Sep 29, 2007
Okay, Coretemp, Speedfan, and Everest are all reporting the SAME temp, but it has to be off. I'm using all latest verions.
(IDLE)
CORE 1 = 26C
CORE2 = 18C
Ambient room temp is at least 22C. I'm also getting a CASE Ambient temp of around 35C (HOT!). I'm using a cheap case thermal probe.
What's curious is that the Tjunction temp (field above the 2 core temp readings) in Coretemp is not displaying. It's blank.
My bios reports the cpu temp idleing around 38C, but none of the programs are reporting that.
Is there 3rd-party app I can use that correctly detects AMD CPU Temp?
(IDLE)
CORE 1 = 26C
CORE2 = 18C
