kaluminati
- Dec 11, 2004
So I recently upgraded cpu to this one, with a Asus p5b mobo.
C2D e6400
Corsair XMS DDR5400 (667) 4-4-4-12 2GB 1gbx2
Athena Power 550Watt psu
x-fi platinum
raptor 74GB - windows drive
evga 8800GTS (not oc'd)
I have been overclocking my cpu, maxium up to 3.2ghz and it's was running fine. I ran memtest a bunch of times and no errors.
So my problem is: At random, or sometimes all the time, xp will start acting retarded. Like I'll have one instance of FF open with maybe 3 tabs, and windows explorer open. When it starts to flip out, I can't right click, I can't open task manager and all I get is the error noise, nothing comes up. I also can't open any new programs and I get the error beep when trying to do that. Sometimes I'll try to open a video, and the program (vlc) will come up half way, and I can't see the video, but hear the sound. To fix it, I have to close FF and windows explorer, then it's back to normal. I've only had ONE blue screen because of this, and it's happened numerous times. This is on a fresh install of XP, and I scanned for spyware/viruses etc. I returned my cpu/ram to stock speeds, still same deal. Ran memtest again, no problems. The temps are fine and below average, since I keep my room cold (35-40 idle for the CPU). I've raised/lowered temps on my Ram and cpu, and updated the bios. My vid card is and chipset have up to date drivers etc etc.
Games run absolutely fine. I've played WoW for 6 hours with no issues whatsoever, besides the weird FF/explorer issues I have while trying to browse while playing.
I'm going to format again and reinstall, but I'm thinkin that it might not help.
Does anyone think my PSU is not enough for this system? I'd think not, but maybe someone else has tried/has a similar setup.
Only thing I can think of, is possibly a corrupt windows install, bad memory even though it tests fine/games run fine, or I'm in need of a more powerful PSU, which seems unlikely since games run perfect. Or perhaps a corrupt FF install that's conflicting with Explorer.
If anyone has any ideas, or has experienced a similar issue, please help me out here, I'm scared I have a bad part in this new system =( Thanks.
C2D e6400
x-fi platinum
