Excellent post. I finally found a good cosmos thread. I was immediately in awe at the case's looks and space, but once the hardware was in the temps were hot. At stock "everything," temps were idling at:
CPU / GPU / System
50 / 58 / 28
I know, I know. I reseated the heatsink (Zalman, 9500) with some arctic silver 5 and directed exhaust towards the top, instead of rear. CPU temp dropped to ~42 C. I installed an extra 80 mm fan pointed at the VGA card which lowered the GPU to ~52. Also removed the sound-proof foam, but not sure if that helped performance (it's definitely louder).
Im really not happy with the temps so far. I plan to replace two of my stock fans. Which fans should I replace...intake plus exhaust? or both exhaust? I think the former since I don't subscribe entirely to the negative pressure concept. I remove the side panel and the temps drop over 5 degrees.
Btw, I'm running a Q6600.
Be prepared to put some time and $$ into the cosmos if you get one. It's definitely not ready to go out of the box. At least not for most people. I will say, though, I'm glad I have one!
Which Cosmos case are you talking about the 1000 or the 1010 other than the case fans not cooling enough ? LED wiring issues or something else ? The 1010 has the side panel cooling fan, and understand better fans all around would be better, but anything else to be conserned about ?
Thanks
The case has potential for great airflow. They aimed for slience so it was fitted with slow, quiet but wimpy fans. I just ordered a couple of Panaflow FBA12G12M1BX fans, one for the bottom intake and one for the rear exhaust. Hopefully I can raise my OC back up to 3.6Ghz, although I also just ordered a second GTX so I don't know how that will affect my case temps. The intake is pointed towards the video cards and there aren't any sources of heat in that area so the cards should be getting cool air. Since the front drive bays are perforated and a good deal of air moves through there, the rear exhaust fan should move that cool air over the CPU HS/F which directs air in the same direction as well. I'm constantly cleaning dust of the bay covers. Hopefully this works out ok.not realy. the only thing to be concerned about is the cooling performance and IMO its one of the most important factors of buying a case. you dont want to buy a case with bad air flow dont you
Good airflow is very important but for a case like the Cosmos you can end up spending quite a few bucks on quality fans for it. I guess if you go cheap and get ball bearing whiner fans you can get a set of four for about $25 but good >80CFM at 35dba fans will run ya $13-16 a piece. I'm thinking about getting some deadening material for the bottom of the case, there are areas that could be covered but aren't. Overall the case is pretty quiet.I agree entirely. Plus, have you seen how sexy the case is?! That was the main selling point for me. Based on a lot of people's reports, just replace the case fans and you should be in good shape. My problem is I don't have those fans yet and I'm trying to squeeze every last bit of performance out of my system.
I went with Panaflo FBA12G12M1BX rebranded as Rexus NMB-MATfrom Newegg. These are HydroWave fans, 3 pin 2100rpm 35dba and they supposedly push 86 CFM. I just got back from UPS, the driver didn't put my box aside so they spent 20min digging mine out of the pile. I'll give y'all my subjective opinion after installation after I finish jumping for joy becuase 1) I got my stuff 2) Apple released a Vista 64bit compatible version of iTunes so now I don't have to use VMWare to sync my iPod touch (slowly) 3) They have apps available for the iPod Touch (We get maps!!!).what fans did you go with, and once you have them fitted can you let us know about noise. i have some sharkoon fans in mine but they spin at 2k RPM so i get a little bit of noise.
