I'm about to call WD and yell at them. Just got a 1.5 EADS back from RMA and WDTLER cannot be enabled on it. Suggestions?
hmm, a tool that is meant for enterprise drives doesn't work on your consumer drive. Good luck with that.
Here's another way to look at this:
What percentage of the enterprise do you think were using these ( EADS ) in arrays?
I'm willing to bet not many.. The people hurt by this are the IT guys like myself that wanted an inexpensive array at home.. I doubt very seriously this was hurting the sales of the RE drives.
</rant>
Tuff shit.
WTF is your problem?
If you are an enterprise customer and buying green drives for mission critical apps then you are a moron. The fact is that they have close to the same firmware for their consumer drives as the enterprise drives. A tool that was available to owners of enterprise drives that was meant to only work with enterprise drives now only works with enterprise drives. WTF is your problem? You bought a drive that wasn't guaranteed to work with TLER and now it doesn't. It's not meant to be run in a RAID array. Tuff shit.
You got the same product back. The drive is the same size, same speed, and same RPM.
they never stated it should have worked in the first place.
Sure it does. An after market app that was meant for enterprise drives doesn't work on it. Its not an enterprise drive and the tool was never meant to run on it.
you can try to reason it anyway you like, the simple fact is that the replacement is less functional than the device under warranty.
As far as I know WDTLER was never made available to the public by WD, but somehow was leaked. You are using a unsupported, leaked tool to enable a function that the drives were never advertised to have. This is more comparable to using a leaked software key to enable a function that was not paid for.
I don't think the WD20EADS has a jumper related to any power modes or staggered spin-up.
The WD20EADS firmware 01.00A01 version does not support APM (Advanced Power Management) mode/features.
Firmware version 04.05.G04 and later do include APM support.
Here's where we obviously differ in opinion:
I feel that regardless of whether or not they intended these drives to be used in Raid or not, they did.. and with TLER they worked pretty well.
Do you really think the fact that TLER was an option to turn on initially was an accident?
For them to disable this on newer versions of the same model is just wrong.. if they want to disable it on future versions.. like the EARS series, thats fine in my book..
But when I RMA a dead WD10EADS that that worked for my needs, and got back a WD10EADS that won't.. That makes me want to start looking for a new drive mfg.
</rant>
Pretty much what WD had to say, but terrible way to treat your customers.
So what was the motive for them disabling this? They won't answer that.. but we already know why..
To prevent all us rich folk from buying cheaper drives instead of their more expensive ones.. I'm already dreaming up what I'm going to do with the $500 I saved by not buying the RE drives..
I sent back a dead product under warranty and got a lesser product back.. plain and simple.. understand now?
They gave him a materially different drive as a replacement for the one that failed under warranty. They are fully within their rights to change the functionality of NEW devices but in a defective product scenario, the functionality needs to be the same or better. If not they aren't replacing the failed part with a comparable part, they are replacing it with a worse part. How would you feel if you RMA'd a 1TB drive and got back a 900GB drive?
The drive does not function to the same specification as the drive he sent in. AKA not the same product. The previous drive was fit for the function it was used for, the new drive isn't, therefore they downgraded him on the replacement, which isn't acceptable.
It's worked for years - are you really being serious here, if so kindly go elsewhere. This is RAID 1 - simple data protection, I don't need to move into another series and spend $$$ on purchasing an additional two drives because my existing drive failed.
A couple of questions.
1. Why would I want to use WDIDLE3, doesn't that defeat the purpose of this being a green drive?
2. What are the benefits of using the firmware posted in the lsi link?
Agreed - and to be honest this is poor business practice on WD's part. The majority of the costs associated with these enterprise drives aren't even related to their components - I don't need the "enterprise" support or guaranteed product life.
While I agree that this is a little bit cheap of WD to remove a function that so many users relied on, you can't blame them that they ty to protect their business.
WDTLER was actually made available by WD for customer use both for the blacks and the RE drives. I don't know where this myth came that WDTLER was never made public by WD, you used to be able to email support and they would give you a link for it. IE, it used to be available from their website.
What are the APM features? Why would a green drive not support APM features, my 2TB has 01.00A01 should I update it?
danman said:Sorry, but you sent them a WD10EADS drive and you got back a WD10EADS drive. Plain and simple, you got back an identical drive (especially from their point of view). You modified this drive with the TLER tool, which if you read the warranty you will know actually voided the warranty on the drive, and they still sent you a replacement drive which if they knew that you tinkered with it, they didn't have to replace it since your warranty was in fact voided!
treadstone said:Precisely!
treadstone said:The fact that some of the green drives could be TLER enabled was more or less an oversight on the firmware programmers
treadstone said:The fact that he was able to change that setting on the old drive just means that he was lucky to get a drive they forgot to disable that feature in the first place!
treadstone said:You can still run this drive in RAID1 or any other RAID array, with the exception that TLER is not enabled and you may or eventually will run into an issue where the drive will get dropped from the array.
treadstone said:Again, see above. It is the EXACT same drive.
treadstone said:Would you still have said that the drive wasn't the same or that it was less functional ???
treadstone said:Again, these tools are not meant for the regular green drives.
treadstone said:The additional cost may not necessarily be related to the cost of the hardware but rather the extended warranty and support you get with the enterprise drives.
omniscence said:You can't blame them that they ty to protect their business
- Wrong, The drive I received was a lesser drive.. they disabled a feature that it once supported. regardless of whether or not they intended it to be there in the first place.
Oversight or intentional, the functionality was there..
IMHO is the functionality was in that particular drive model, it needed to stay there throughout its lifecycle
Without TLER these drives WILL fall out of a RAID5 or 6 array.. its just a matter of when, unless you can set the timeout value on your RAID controller
I simply do not understand your logic here. Its NOT the EXACT same drive.. or we wouldn't be having this discussion would we?
Yes, If I was aware that the drive I received was of less usefulness than the one I returned.
Irrelevant.. the tool is used to turn on TLER, the drive I originally had supported TLER
WD keeps telling me that the RE drives are typically 15-25% more.. as I stated it is simply not true.. or this wouldn't be as much of an issue
Protect it from whom? They protected themselves out of a home customer and a business customer.. all because some brass hat thought this was cutting into their bottom line.. plain and simple it just couldn't have been.
I buy on average of 2 WD products a week for the last 3 or 4 years.. not anymore
Really, do you guys that are defending them work for them?
I just don't understand how you could defend them in this..
Western Digital obviously knows this has been an issue with many home enthusiasts such as myself, otherwise they wouldn't have been so quick to offer me an RE drive.
What they need to do, is turn the functionality back on that they broke..
No one has touched the subject of the motives of disabling this..It like WD is your football team and you are going to defend them regardless of what they do
What would you have to say, if they released a 1TB hard drive.. that actually had 1TB of usable space, then later they decided this was a mistake and set the usable capacity to 931GB so that they could sell more of their true 1TB drives that were twice as much?
Again, see above. It is the EXACT same drive. So he got back what he sent to them. Look at it this way. if he would have never enabled TLER on the original drive and he would have had to RMA the drive, he would have gotten the exact same type of drive back from WD. Would you still have said that the drive wasn't the same or that it was less functional ???
Again, these tools are not meant for the regular green drives. These tools are for the enterprise RAID type drives (RE drives). And yes, the WDIDLE3 program basically defeats the green features of the drives IF you disable that particular feature which means the drive will end up using more power.
It was made available to the public at one point but after WD found out that people were misusing this tool by modifying drives other than the RE drives for which the tool was originally made, they pulled it. So you can't blame WD for trying to protect their products.
This is a completely different situation. The processor you bought is advertised as having these features, so you have a right to receive a replacement that also has these features. If you however buy a (3 core) Phenom X3, use the unsupported core unlocking features of some motherboards to make it a quadcore and then the processor somehow breaks, you may get a replacement where you cannot activate the last core. I doubt that you can convince them to send you another X3 processor with 4 working cores.No it isn't the exact same drive, this is in fact self evident. Anyone arguing that it is the exact same drive needs to think a little. Second, it isn't even the exact same specification, the drive sent in supported TLER, the drive sent back did not. What if you bought either an intel or amd processor that supported turbo boost, it failed, sent it in for RMA and they sent you one that varied substantially in its capability such that TB was now only active when 1 core was active instead of when multiple cores were active?
Model 00W4B0 production date july 2010. Unable to change/view TLER
Got 6 more new drives with production date july/august 2010 models 00R6B0 and 00S2B0.
I was able to enable tler on all 6!
