so is it a yes or no ? is the AALS faster then the AAKS?
AAKS vs. AALS
i read the whole thing but i can't tell
I ran the test using HDtune for the AALS, but the test from the AAKS was not from me. In order test these accurately a test using both drive on the same machine will need to be done, I can't do this because I don't own an AAKS drive.
I don't think the AALS is slower than the AAKS but I also don't think its any faster. If the extra warranty and lower cpu usage is important then spend the extra $5-10 dollar for the AALS otherwise save that money and get the AAKS.
Looking at those tests posted on the first page of this thread and seeing the burst speeds of < 150MB makes me think the person doing the testing doesn't have these drives running in SATA II mode. There is no way in Hell these drives can't pump out 230MB or higher in burst speeds so, perhaps if he/she/it redid the benches using proper SATA II mode the numbers just might climb higher.
I see this shit all the time around here when people do benchmarks and it's the very first thing I look for - the burst speed. If I see < 150MB then I know they're not set up correctly and stuck in the slower SATA I mode. I don't know why people seem to miss this point of the testing, but they always do...
Well, I'd like to know what I'm doing wrong. My Seagate 7200.10 500GB drive says to use NO jumper for SATA II. That's how it is configured. I get 137.4 burst speed in Vista x64 with advanced performance enabled in device manager.
Same thing for the WD6400AAKS. 147 burst with no jumper and advanced performance enabled.
Motherboard is Gigabyte P-965-DS3 with latest Intel motherboard drivers.
I just replaced my aging 74Gb Raptor
Here are benchmarks of both:
thank you for this.
I'm rocking that exact raptor 74gig. Would you say it should be a no-brainer to upgrade to a 640 AAKS or AALS for my new i7 build?
wow. Cheaper and faster then 300Gb raptor. Wow.
Benchmark was used on the system in the signature. (P.S. - F*** VRaptors)
WD Caviar Black 640GB -
2 x WD6401AALS (74.99 x 2 = $150) setup on ICH10R matrix raid.
Raid 0 Volume - 161gb - 128k stripe. (Second Volume is Raid 0 1119GB)
Slight Dip in minimum due to activity spike
