After doing much research, I have decided to buy a D-Link DGL-4300 (http://games.dlink.com/products/?pid=370&#DGL-4300). I really wanted the Netgear WPNT834 (http://www.netgear.com/products/details/WPNT834.php), but it seems the DGL-4300 meets my needs better. Anyways, I can find hundreds of great and not-so-great reviews of routers, but I haven't seen any reviews on wireless NICs.
So my question is, what is good (reliable, fast, good driver support, etc.) wireless NIC made by D-Link that will work with this router? I was loking at these three (http://www.newegg.com/Product/Produ...rtyCodeValue=0&Submit=Property&SubCategory=31) but honestly, I don't have a clue.
EDIT: It needs to support WPA2. It would also be nice if it was compatible with the Netgear WPNT834... just in case. Also, if you didn't check out the links, I need/want a PCI NIC.
