penguin said:Water is actually pretty much the best thing for the job, unless you want to get into super expensive weird chemicals and stuff.
BillParrish said:QFT
You cant beat distilled water with anything you can buy over the counter or that will work in a conventional water cooling setup. Anything else is 90% water with stuff in it to glow, prevent corrosion, or kill bugs.
Glowy can be cool, your call.
Use all copper/brass/anodized aluminum and you wont get corrosion anyway.
Washout/dunk everything in alcohol rinse with distilled water and dont spit in it and you wont have bugs.
A gallon of steam distilled water from the grocery store, a quart of Isopropal Alcohol from drug store and with clean assembly you get as good as it gets for about $2.
annaconda said:What about CAR AntiFreeze 50/50
n1ce_hat said:2% milk usually does the trick
