EarthBrain
- Sep 5, 2007
What is the most powerful fanless Nvidia card?
ATI has so many but I don't see much for Nvidia cards.
Why fanless? Noise or space? There are options available for low db, and low profile fans.
Stick this on your videocard.
Buy a GTX460, get some aftermarket heatsink, and put on a 800rpm 120mm fan. Passive = pain in the ass that isn't worth it. The cooling difference between passive & inaudible fan is huge. I think Scythe even sells 500rpm 120mm fans, and you can probably check SPCR for their real db rating... it'll probably be <17db.
