But I thought all the socket 1156 CPUs were dual channel, including the i7 860? And how di I know if a RAM is dual or tri channel?
It's the motherboard/processor that determines how many channels are supported. Manufacturers just package two or three sticks together and call it a X channel kit. The modules themselves are no different from the ones sold individually.
DDR3 1600 seems to be the sweet spot. Personally, I recommend this low voltage 6GB kit.
Since I have a dual channel system, I would have to get 8GBs and fill out all the slots to get dual channel, correct? Unless, I went with 4GB of course, but that seems low.
Any recommendations there?
Yes. In order to run your RAM in dual channel, you would need for the number of sticks to be a multiple of two. Your options are 2x1GB, 2x2GB, and 2x4GB. This 4GB G.Skill DDR3 1600 kit is a good place to start and runs at a low voltage (1.5v). 8GB will be considerably more expensive around $240 with something like this Corsair kit. If you really need 8GB, I would probably just purchase two of those 4GB G.Skill kits that I linked you to.
He could also do 2x2GB and 2x1GB for 6GB and still keep dual channel.
True, but it is preferable that all of the sticks be of the same capacity.
yea it really doesnt matterwhy? as long as they're the same speed, timing, and voltage, He can get more than 4GB of ram and save a penny or two by not going all the way to 8GB.
Just to confirm, I can do 6GB with 2x2GB and 2x1GB and still get dual channel?
Thanks
Thanks
You could, but that's kind of ghetto. Might as well go with just 4GB to start and max out to the 8 GB later if you decide you need more RAM. Think of it this way, if you ever decide you want 8 GB instead of 6 GB with a 2+1 setup you'll have to throw away two perfectly good 1GB sticks. Whereas if you go with 2x2 for now and decide you need more memory later, you can just buy 2 more 2 gig sticks and not waste any ram/money.
X58=3 channel
P55=2 channel
Ahh, thanks for this info, never knew this. Thought they were different in some way.It's the motherboard/processor that determines how many channels are supported. Manufacturers just package two or three sticks together and call it a X channel kit. The modules themselves are no different from the ones sold individually.
Tri-Channel DDR3 RAM for Core i7 X58
Dual-Channel DDR3 RAM for Core i5/i7 P55
Speed wise, DDR3 1600 RAM seems to be one of the better bang for the buck RAM speeds out there. However DDR3 1333 is also a good choice if it's significantly cheaper.
