I own a Cooler Master CM 690 II Advanced case.
http://www.coolermaster.com/product.php?product_id=6638
I have a Sandy Bridge i5-2500K processor. I want to run it at atleast 4.0GHz each core. It's currently sitting in there with a Corsair H50. Idle temps are around 35-40, load temps are around 60-62 (both Celsius).
I have a PNY XLR8 GTX 580. However, I think if I want to water cool it, I'll be voiding the warranty and having to purchase a $100 or so waterblock.
I am game to purchase the MSI watercooled GTX 580 instead, and sell off the PNY.
What I want is to make this computer as cool and quiet as possible without spending unnecessarily to do so. It now looks like I'll be having to use it as my main rig which will be on for 16 hours a day or so, indefinitely. Right now, it's not necessarily loud, but it does generate some audible noise and spits out enough heat to warm up the room. I'd like to offset that and I'm thinking water cooling.
So what would you do? I can keep the Corsair H50 and create a single loop for the GTX 580, or sell off the Corsair H50 and go for a two step CPU/GPU loop. I don't know what parts would serve me best in the case of my components, o/c aim, and case.
By the way, I have a Corsair 850w in there and three case fans.
