Providence
- Apr 23, 2006
http://www.newegg.com/Product/Product.aspx?Item=N82E16835227002
$320
http://www.newegg.com/Product/Product.aspx?Item=N82E16835227001
$190
It looks the same....?
Sorry, I'm really new to this, but I'm building a rig that's going to be in a place that really needs to be just a bit quiet and NOT put out much heat. I just want to cool my GPU's and my CPU...but what's the difference between these guys?
EDIT: Also, rather than make a new topic, I'll ask here.
This says it will cool both my GPUs and my CPU. I know quad cores are also LGA775, but just to make sure: Will a qx processor be compatible with this? Just making sure...
Another edit: Sorry, I'm really new at cooling >_> Anyway, from what it looks like, I can buy a "block" for my 8800GTS and install it on the card, and integrate it somehow into the Corsair Nautilus 500, cooling both the CPU and the GPU.
Correct?
$320
$190
Correct?
