I'm curious, when you see the 80% efficiency on power supplies are they referring to running the power supply at 80% of it's capacity that it's efficiency will be tolerable? For instance if you have a 750 Watt power supply, you would want to run it no more than 80% of it's rating? So everything is running 600 watts in your system a 750 watt supply is sufficient? Anything higher you would want to run 800 watt or higher?
Basically I'm trying to gardner the tolerable limit of running a power supply 24x7....
