Optimummind
- Feb 11, 2004
As Koolance owners already know, there are 3 80mm fans blowing on top of the radiator inside that long, black sleek case. The air is blown upward.
Now, I was wondering, would my temperatures be improved if I were to reverse the orientation of those 3 fans so that the airflow in directed downwards??
Due to summer heat, my idle is around 34-36 and load is 37-38 C. With my AC on during the day, the temp goes back down to the 26-29 range.
So, what do you guys think? Should I try to reverse the orientation of the fans or is it a waste of time??
