Dec 2, 2005 #1 P prophetx2 Limp Gawd Joined Nov 27, 2005 Messages 201 anyone cooling an ati 1800 card? I was looking at the maze4's but, not sure if it fits. thanks in advance!
Dec 2, 2005 #2 B BioPort Gawd Joined Oct 6, 2004 Messages 754 maze4 fits, i have one on mine right now. it basically uses the same 4 hole pattern that the 6800-7800 series cards use.
Dec 2, 2005 #3 J Jonsey [H]ard|Gawd Joined Dec 8, 2003 Messages 2,041 I used the low profile version of the maze4 for my x1800 xl. I asked for the version for 6800/7800 cards. My old maze4 had only two holes... not sure if that would work on the newer cards, I never tried it.
Dec 2, 2005 #4 E EzekialRage Gawd Joined Jul 25, 2001 Messages 580 the maze4 or the mcw55 i think it is... whatever switfie's block is. personally, i'd go with the maze4
Dec 2, 2005 #5 P prophetx2 Limp Gawd Joined Nov 27, 2005 Messages 201 looks good guys! Can't wait until i get my first watercooling setup running. Off hand how many ramsinks do i need for an 1800?
Dec 2, 2005 #6 E EzekialRage Gawd Joined Jul 25, 2001 Messages 580 should be 8 for a 256meg card (might want to have someone verify that since i don't have the 1800)
