What should I get, is 667 with higher latency better than 533 with lower latency? Also what brand uses better memory chips? Here's some of the cheaper ones I've found,
http://www.newegg.com/Product/Product.asp?Item=N82E16820227059
http://www.newegg.com/Product/Product.asp?Item=N82E16820231050
http://www.newegg.com/Product/Product.asp?Item=N82E16820145526
I plan to overclock, but that really shouldn't make a difference since the memory timings can be locked right? Oh, and yes I've been searching over the board for this info, so thanks for any help.
