Scheizekopf
- Jan 31, 2003
Umm...?CzarDestructo said:i tossed my Truepower 380 into my ultra cheap 850mhz PCChips PC because thats all i feel it merits. moves no extra air so it radiates a lot of extra heat.
I can understand his disappointment with the TP380S model, the "S" stands for "single fan" and might actually be the reason his psu runs warmer than usual. You could probably rig a second 80mm fan to help alleviate the psu temps but many people aren't inclined to do so (understandably i guess)CzarDestructo said:I'm aware of how it works, it doesn't move any extra air,only what it needs to keep from overheating. so its alway running hot and radiating heat. also the model i got with my Sonata doesn't have a second fan so the whole top of my case got VERY hot.
my voltages on the superflower are marginally better than the Antec,but thats because the antec did fine anyhow,its just the airflow issue i didn't care for.
and yes, the 140mm fan moves 50CFM silently. its a huge fan that has 11 blades,it moves a lot of air and it does so silently(i guestimate it at 30dB when the PSU is in max cooling mode). if you don't believe the specs check the Globe fan website or buy a cheap 350watt model for $30.
