I would use the motherboard ports for that. Remember that hard drives do not need SATA III at all. The fastest hard drives today have just broken the SATA I barrier and are very far from breaking the 300 MB/s that SATA II provides. Your P6T Deluxe already has good SATA II ports.
Looking for a good SATA III RAID controller under $500, need to be compatible with an older Asus P6T Deluxe mobo on Windows 7 64bit OS. Will use it to host a single Samsung 830 256GB SSD, and 3x SATA III 7200K HDD on the controller in RAID 0.
make sure you come back and report when you have problems with that raid 0 array. I give it 300 days
Yes. Don't put an SSD on it as it hasn't got fastpath and thus will be slower than the internal ports. Also, RAID needs a key to work. Move your data drives on it, for example.
