chinked|out
- Feb 6, 2006
Intel TAT, it is their processor after all.
TAT is reading (directly I beleive) the thermal diode inside the chip and converting to temp.
Speedfan is getting its information from the SMS buss monitoring chip so there are several "layers" if you will, of code and conversions going on.
run Coretemp, almost all of us use TAT or Coretemp and so far (new 680i boards excepted) they agree very well.
Also based on my experience, beleive me when I say you aint gonna get 43c on a 6300 at 3GHz at full load
no, Coretemp and TAT good !!! use either one you want. they should agree and typically do. Both read chip temp directly.
TAT is nice because it has the loading software included. Coretemp is just temps and we typically use Orthos to load the cpu for testing when using Coretemp.
It really does not matter, both programs have shown themselves to be very accurate on Intel chipset boards.
OH JEEZ I AM AN IDIOT So Sorry no wonder you are confused. My bad !!!!
I did a quick glance at the pics and saw Speedfan was running and missed you had coretemp up too, thought it was cpu-id and didnt even look at it. dumb dumb dumb bad Bill BAD !
I hate to say it but speedfan and coretemp are in close agreement and I dont trust speedfan and the speedfan and coretemps temps seem a little too good frankly. Soooooooo I dont farking have any idea but if you put a gun to my head...
actully scratch that, I dont have a clue, and gonna stf up, you need to find another owner of that board.
my room temp is actually 60F without heater on.judging your idle temps i'd say TAT is the acurate one. 19c is 66f, and at the same time your cpu is at 66, your motherboard is registering 89f. average room temperature is about 71f, so 66 at idle couldn't happen, slightly over 100 seems a bit more like it, and thats where my 6600 idles.
i have no proof as to what i say, just and educated guess.
On most boards TAT and CoreTemp are usually pretty close since they are reading from the same sensors but in your case, TAT appears to be right and CoreTemp wrong.
SpeedFan v4.32b17 is available which now includes reading of the sensors within the Intel core. Previous versions were reading from a motherboard sensor which isn't the same.
On my P5B Deluxe, CoreTemp and SpeedFan 4.32 are exactly the same from low temp to high temp. It would be interesting to see what this new version reports on your board. Remember to let all of the temps stabilize before snapping a screen shot.
http://www.almico.com/sfbetaprogram.php
Here's some interesting numbers.
I have an E6400 but I dropped the multi down to 7 and set the FSB to 422 MHz to simulate your setup. I also set it so CPU-z was reporting 1.312 volts at idle and 1.288 volts while under load running Orthos.
Room temperature when I started was 13C in my basement when I started this test and went up to 14C when I ran the idle test. This is just slightly cooler than your room temperature of 60F (~15C ).
Using CoreTemp & Speedfan the temps under load went as high as 52C and then settled out at about 50C. Idle temp was reported as 20C.
The biggest difference between our setups is the heatsink and fan. Your Zalman 9700 significantly outperforms my Intel OEM heatsink and fan so your temps should be cooler than this and they are. If my computer was operated at your room temperature then my load temp would probably be about 53C. Your load temp of about 47C with a much better cooler makes perfect sense.
Anandtech did a review of the Zalman 9700. On an X6800 at 2.93 GHz their load temp dropped by 20C from 56C to 36C and their Idle temp went from 41C to 28C. Knowing this, it's possible that after you properly apply some AS5 and give it time to setup, your CoreTemp readings might even decrease a few degrees.
http://www.anandtech.com/casecooling/showdoc.aspx?i=2932&p=1
While experimenting I've seen CoreTemp readings of 80C at which point the Intel C2D thermal throttling kicked in to keep the temps from hitting the Intel maximum of 85C. I have no doubt that CoreTemp is reporting the correct temperature on my P5B Deluxe.
I'm also convinced that on your board CoreTemp and the new version of SpeedFan are reporting your real core temperature. The Intel TAT program is reporting about 3C less at full load on my board but seems to be out to lunch on your board. If I was you, I'd be trusting CoreTemp.
NOTE: Orthos and CoreTemp report 3376 MHz because they're incorrectly reading the multiplier. It knows it is an E6400 so it assumes I am running it at 8 X 422 MHz = 3376 MHz when it's actually running at 7 X 422 MHz = 2954 MHz.
If my testing doesn't convince you then nothing will.
Too many people have been brainwashed into believing that TAT is perfect because it was made by the big Intel corporation but obviously on some boards, like yours, it is not correct. It needs to be updated for proper C2D operation but it hasn't been updated for quite a while.
CoreTemp and Speedfan are simply reading a register within the C2D processor and displaying the result. On my P5B Deluxe you could argue whether CoreTemp or TAT is displaying the true temperature but on your board there is nothing to argue about. The cool room you use your computer in leads to some cool CoreTemp numbers but they certainly make perfect sense compared to what TAT is showing on your board.
CoreTemp has reported my E6400 at every temperature from 20C to 80C without any problems. Your numbers and my testing in a similar environment confirm that CoreTemp is reporting the correct temperatures. I'll have to go and post on his forum and tell him that his program is working as it should.
By the way, did you use AS5 on your processor when you installed it and how did you apply it? I found that the AS5 guide that shows that you should draw a line down the centre of your C2D didn't work very well for me. Covering the centre of the heat spreader where the core is located with a thin even layer was more effective.
OT: Another thing that most users don't want to hear is that I gained absolutely nothing by replacing the Intel thermal paste with AS5. So far after a few days of break-in, the before and after temps are exactly the same. Can anyone find me a link to a reputable review of AS5 in a controlled environment vs the 3 strips of goo that Intel puts on their heatsinks?
i'm not saying i don't believe your testing on the temperature. but i'm just saying why do most people believe it is right to use TAT? haven't people tested for themselves? or everyone like you said is truely brainwashed. i did see how as5 is supposed to be applied. but what i did when i applied it was put a small dot amount on the center and then put my heatsink on it and then turned the heatsink right and left to smudge it then screw it on. i didn't draw a line like it said i should.
another thing is that i live in SF. it's cold these few days. i have my heater set to 68F. so i dunno if my idle temp is still correct since it could range 18-20c at 68F room temp
posted the test of yours in XS
http://www.xtremesystems.org/forums/showthread.php?p=2034158#post2034158 hope that's okay with you
Something wrong because I just checked both of these on my rig. The stock E6600 speeds Core Temp shows temps are;
Core 0 = 34C
Core 1 = 35C
TAT temps are:
Core 0 = 35C
Core 0 = 36C
I went it at stock to compare to others so overclocking wasn't affecting it. I'm using a Ninja Cooler with the 120mm fan set to low speed for the test. TAT monitors more often than Core Temp, I had speed-ed it up yet. The difference I see is about 1 to 2C.
On a board with the 965 chipset like a DS3 or P5B, CoreTemp and TAT report very similar temperatures.Something wrong because I just checked both of these on my rig.
The E6300 and E6400 are not Allendale. They are Conroe with 2MB cache.yes because i'm on allendale core.
Allendale refers to the new E4300 processors.
http://en.wikipedia.org/wiki/Intel_Core_2
That's the problem with forums. If the same lie is told enough times, people start to believe it, even if it isn't true.
Now that the real E4300 Allendale is available, some programmers are updating their software to report the Intel C2D properly.
CPU-z, v.1.38 reports the E6300 / E6400 as Conroes, which they really are.
http://techreport.com/reviews/2006q3/e6300-vs-sff/index.x?pg=1
The first of our two contestants is the Core 2 Duo E6300, the humblest of Intel's new Core 2 processors. Unlike its fancier big brothers, the E6300 has only 2MB of L2 cache to share between its two execution cores. You'll find plenty of sources that will tell you the code name for these 2MB Core 2 Duo processors is "Allendale," but Intel says otherwise. These CPUs are still code-named "Conroe," which makes sense since they're the same physical chips with half of their L2 cache disabled. Intel may well be cooking up a chip code-named Allendale with 2MB of L2 cache natively, but this is not that chip.
Correct.so you guys are saying i'm not using a allendale e6300?
yes because i'm on allendale core. which ameks a huge difference in temp. the 6600 and above aren't allendales.
The problem is that on other boards TAT is not accurate. Too many people are relying on this program even though it hasn't been updated for the C2D processors and the collection of different chipsets available for the C2D.
People have been doubting CoreTemp because they assumed that TAT was correct but testing shows that TAT is definitely not correct on some motherboards.
Do you have a date code on your L2 E6300? I believe the original E6300 chips were all Conroe stepping B2 and it's only recently that the L2 E6300 chips have been in production. Thanks for finally clearing things up.just got confirmation regarding conroe and allendales.
Cracker said:Actually, an E6300 can be either a Conroe or an Allendale depending on the stepping with the earlier chips being Conroe and some of the newer ones being Allendale. Here is a good thread on this subject LINK
And for a listing of the s-spec's and steppings to further explain here is an Intel link. LINK L2's are Allendale and B2's are Conroe.
