Page 5 said:Whats New in Version 185.85
Added support for the NVIDIA GeForce GTX 275.
This driver version adds support for NVIDIA PhysX acceleration on all
GeForce 8-series, 9-series and 200-series GPUs with a minimum of 256MB
dedicated graphics memory (this driver package installs NVIDIA PhysX
System Software v9.09.0408).
Note: The NVIDIA Control Panel erroneously reports the PhysX software version
as 9.09.0203. If you have installed graphics driver version 185.85, then the
NVIDIA PhysX software installed is version 9.09.0408.
See Changes in Version 185.85 on page 6 for a list of resolved issues in this
release.
Page 6 said:There are no bug fixes to report since version 185.81.
Got a problem with 185 and movies. The picture get's all flickery and noisy. Had to go back to 182.
using 8800GTS 512, Vista 64, Media Player Classic.
May I ask what this ambient occlusion does?
Well, I probably won't understand the technical details of what it is, but I want to know is it an extra feature like AA and AF
Or is it a technique that is used by certain game engine that if I turn it off, i will be disabling such feature in that said game?
Thanks
little of a and a little of b
Ambient Occlusion gives everything a sort of "fuzzy" look. Its a bit of a compromise, the extra depth is good, but the performance hit and fuzziness is bad.
AO is purely a visual boost at the cost of performance and no, there was nothing in the notes about improvements to that game.Will this Ambient Occlusion and driver update help with phantasy star universe for the PC?
I seem to have lost my SLI (2x 8800 GT) and device manager shows only one display adapter. . .
WTF!¿
