LunchboX3904
- Apr 13, 2005
Dots per Inch is a measurement used both on monitors and printers. The measurements are done different ways though. The higher numbers on printers generally represent more detailed print quality (i.e. 1440x1440 would be very high resolution printing). The lower numbers on monitors represent clearer picture quality (i.e. .22 dpi would be a very high quality monitor).
In order to produce high-quality images, it is important to understand how the pixel data of images is measured and displayed.
Pixel dimensions
The number of pixels along the height and width of a bitmap image. The display size of an image on-screen is determined by the pixel dimensions of the image plus the size and setting of the monitor.
For example, a 15-inch monitor typically displays 800 pixels horizontally and 600 vertically. An image with dimensions of 800 pixels by 600 pixels would fill this small screen. On a larger monitor with an 800-by-600-pixel setting, the same image (with 800-by-600-pixel dimensions) would still fill the screen, but each pixel would appear larger. Changing the setting of this larger monitor to 1024-by-768 pixels would display the image at a smaller size, occupying only part of the screen.
When preparing an image for online display (for example, a Web page that will be viewed on a variety of monitors), pixel dimensions become especially important. Because your image may be viewed on a 15-inch monitor, you may want to limit the size of your image to 800-by-600 pixels to allow room for the Web browser window controls.
Example of an image displayed on monitors of various sizes and resolutions
Image resolution
The number of pixels displayed per unit of printed length in an image, usually measured in pixels per inch (ppi). In Photoshop, you can change the resolution of an image; in ImageReady, the resolution of an image is always 72 ppi. This is because the ImageReady application is tailored to creating images for online media, not print media.
In Photoshop, image resolution and pixel dimensions are interdependent. The amount of detail in an image depends on its pixel dimensions, while the image resolution controls how much space the pixels are printed over. For example, you can modify an image's resolution without changing the actual pixel data in the image--all you change is the printed size of the image. However, if you want to maintain the same output dimensions, changing the image's resolution requires a change in the total number of pixels.
Example of an image at 72-ppi and 300-ppi
When printed, an image with a high resolution contains more, and therefore smaller, pixels than an image with a low resolution. For example, a 1-by-1-inch image with a resolution of 72 ppi contains a total of 5184 pixels (72 pixels wide x 72 pixels high = 5184). The same 1-by-1-inch image with a resolution of 300 ppi contains a total of 90,000 pixels. Higher-resolution images usually reproduce more detail and subtler color transitions than lower-resolution images. However, increasing the resolution of a low-resolution image only spreads the original pixel information across a greater number of pixels; it rarely improves image quality.
Using too low a resolution for a printed image results in pixelation--output with large, coarse-looking pixels. Using too high a resolution (pixels smaller than the output device can produce) increases the file size and slows the printing of the image; furthermore, the device will be unable to reproduce the extra detail provided by the higher resolution image.
Monitor resolution
The number of pixels or dots displayed per unit of length on the monitor, usually measured in dots per inch (dpi). Monitor resolution depends on the size of the monitor plus its pixel setting. Most new monitors have a resolution of about 96 dpi, while older Mac OS monitors have a resolution of 72 dpi.
Understanding monitor resolution helps explain why the display size of an image on-screen often differs from its printed size. Image pixels are translated directly into monitor pixels. This means that when the image resolution is higher than the monitor resolution, the image appears larger on-screen than its specified print dimensions. For example, when you display a 1-by-1 inch, 144-ppi image on a 72-dpi monitor, it appears in a 2-by-2 inch area on-screen. Because the monitor can display only 72 pixels per inch, it needs 2 inches to display the 144 pixels that make up one edge of the image.
Printer resolution
The number of ink dots per inch (dpi) produced by all laser printers, including imagesetters. Most desktop laser printers have a resolution of 600 dpi, and imagesetters have a resolution of 1200 dpi or higher. To determine the appropriate resolution for your image when printing to any laser printer, but especially to imagesetters, see "screen frequency."
Ink jet printers produce a microscopic spray of ink, not actual dots; however, most ink jet printers have an approximate resolution of 300 to 720 dpi. To determine your printer's optimal resolution, check your printer documentation.
Screen frequency
The number of printer dots or halftone cells per inch used to print grayscale images or color separations. Also known as screen ruling or line screen, screen frequency is measured in lines per inch (lpi)--or lines of cells per inch in a halftone screen.
The relationship between image resolution and screen frequency determines the quality of detail in the printed image. To produce a halftone image of the highest quality, you generally use an image resolution that is from 1.5 to at most 2 times the screen frequency. But with some images and output devices, a lower resolution can produce good results. To determine your printer's screen frequency, check your printer documentation or consult your service provider.
Note: Some imagesetters and 600-dpi laser printers use screening technologies other than halftoning. If you are printing an image on a nonhalftone printer, consult your service provider or your printer documentation for the recommended image resolutions.
Screen frequency examples: A. 65 lpi: Coarse screen typically used to print newsletters and grocery coupons B. 85 lpi: Average screen typically used to print newspapers C. 133 lpi: High-quality screen typically used to print four-color magazines D. 177 lpi: Very fine screen typically used for annual reports and images in art books
File size
The digital size of an image, measured in kilobytes (K), megabytes (MB), or gigabytes (GB). File size is proportional to the pixel dimensions of the image. Images with more pixels may produce more detail at a given printed size, but they require more disk space to store and may be slower to edit and print. For instance, a 1-by-1-inch, 200-ppi image contains four times as many pixels as a 1-by-1-inch, 100-ppi image and so has four times the file size. Image resolution thus becomes a compromise between image quality (capturing all the data you need) and file size.
Another factor that affects file size is file format--due to varying compression methods used by GIF, JPEG, and PNG file formats, file sizes can vary considerably for the same pixel dimensions. Similarly, color bit-depth and the number of layers and channels in an image affect file size.
Photoshop supports a maximum file size of 2 GB and maximum pixel dimensions of 30,000 by 30,000 pixels per image. This restriction places limits on the print size and resolution available to an image.
Apple's 72 dpi logical inch was close to accurate text size on the early Macintosh screen (1984), which is why Apple selected the 72 dpi number back then. Apple still uses that number today for text logical inches, but that number was only about the size of THAT screen. That 1984 Macintosh graphical screen was something new, it could show various font faces and sizes, italics and bold, even proportional fonts on the screen for the first time. We take this for granted today, but graphic text on the video screen was a new idea then. MS-DOS screens did not show graphic text, and instead used screens dimensioned as 80x25 fixed-width characters of one bit-mapped font.
And back then, Apple did brag about 72 dpi and about WYSIWYG (What You See Is What You Get), meaning text on that screen looked the same, and matched the size of the same text printed on paper. The size accuracy was not because of the number 72 dpi per se, it was because this logical inch size was selected to match this physical screen size. We don't hear about WYSIWYG today - it is not possible now because modern screens vary in size.
Microsoft later used 96 dpi logical inches in Windows to intentionally show larger screen text for better readability
Each of the three images below are 412x324 pixels in size, which is why the video system shows each of them as 412x324 pixels size on the screen.
To make the point that the image resolution dpi number (the scaled printing resolution stored in the image file) simply does not matter on the screen, these three images below are now scaled individually to 7 dpi, 72 dpi, and 720 dpi. If you print them (using a photo editor), they are now three very different images in that regard. These image files actually do individually contain these three different dpi numbers, which is instruction to the printer how to print them (how to space the pixels on paper, how large to print the image on paper).
412 x 324 pixels, 7 dpi, prints 58 x 46 inches
412 x 324 pixels, 72 dpi, prints 5.7 x 4.5 inches
412 x 324 pixels, 720 dpi, prints 0.57 x 0.45 inches
Frankly, I don't see much difference on the screen. <grin> (and this is YOUR video system that we are using too). I am not making this up, you can see what in fact actually happens, and it's going to be real hard to dispute that. But for anyone who still wants to argue that there is any significance of 72 dpi (or 96 dpi) on the screen, please begin by explaining why there is no evidence whatsoever of it on the screen. If 72 dpi matters at all, then how can these three very different images appear identical? Please also explain how any 72 dpi notion might have been used to create these 412x324 pixel images from small 35 mm film (film size is 36x24 mm, about 1.4 x 0.92 inches).
I am teasing - I know it is not possible that anyone can explain how 72 dpi is important in any way to these (or any) screen images. The notion of 72 dpi is flat wrong - video simply doesn't work that way. There is no concept of dpi on the video screen. It should instead be very clear from the above example that images are obviously shown on any screen only according to their size in pixels. In every case, you should just create the image size (pixels) that is the size that you want to see (pixels). So, forget about 72 dpi, it does not work that way. 72 dpi is a false notion, even worse than useless, because it is counter-productive, both to results and to understanding how it really works. There is no concept of dpi in the video system. There are only pixels.
Some dot-pitch basics first: Monitors create colors with red, green, and blue phosphors. By lighting them up in different intensities, the display creates the illusion of other colors. In the vast majority of tubes, these colored phosphors repeat in patterns, with alternating rows offset from each other. Dot pitch is the distance, center to center, between the two closest dots of the same color; each set of three of the closest red, green, and blue dots is called a triad. Notice that a given dot lies halfway between dots of the two other colors in the row below. Each dot also lies directly above the same color dot two rows below.
In most CRTs, the vertical dot pitch the vertical distance between the centers of two same-colored dots matches the diagonal dot pitch, which is the distance between either dot and the closest same-colored dot on the row between the two. Draw lines between the three dots, and you get an equilateral triangle.
The Hitachi CRT arranges the phosphors slightly differently. Here, if you draw lines between the three closest dots of a given color, you don't get an equilateral triangle. You get an isosceles triangle, with two equal-length diagonal sides 0.26mm in this case and a slightly longer vertical side. For lack of a better term, we refer to this as an asymmetrical arrangement.
So in an asymmetrical arrangement, the diagonal dot pitch becomes the closest distance between two dots of the same color. But using that as the dot-pitch spec presents a problem, because a 0.26mm diagonal dot pitch in an asymmetrical arrangement is not equivalent to a 0.26mm dot pitch in a standard CRT.
You can see the difference by examining the horizontal component of the diagonal pitch (the horizontal dot pitch), which turns out to be a useful measurement. When you divide this pitch into the image width, you get the maximum number of triads that fit across the screen--which is also the maximum theoretical resolution the CRT can handle, assuming the monitor electronics are up to it.
For a standard CRT, the horizontal dot pitch equals 0.866 times the diagonal pitch, which comes to 0.2252mm horizontal measurement for a 0.26mm diagonal pitch; this calculation is derived from the geometric properties of equilateral triangles. But for an asymmetrical arrangement, with its isosceles-based geometry, the calculation depends on both the vertical and diagonal pitch of the particular CRT. That means you either need more information to perform the calculation, or you need someone to provide the data.
The Hitachi CRT's horizontal dot pitch happens to be 0.22mm. This turns out to match the horizontal dot pitch of a standard CRT with a 0.254mm diagonal dot pitch. Most of the manufacturers who use the Hitachi CRT quote the horizontal dot pitch value of 0.22mm. However, several including Optiquest®, Princeton, and Sampo® --specify the diagonal dot pitch instead.p
LunchboX3904 said:but quite unnecessary.
LunchboX3904 said:wow dude. ummm, i just wanna know how to make my pics open up in photoshop at 72 dpi.
I looked through the manual for the camera but I didn't se anything on it. I remember reading about a print setting somewhere but forgot about it. The reason for 72 dpi, is because that's just what I have always worked at in photoshop and the fonts did what they were supposed to, so no need to change. well, I really appreciate all your help.....you win some, you lose some.Ice Czar said:72dpi is a mac standard regarding the size of the graphics appearing on your monitor screen
if its a apple monitor circa 1984
you need to refer to the documentation of whatever it is (the camera?) that placed the digital watermark on the photos
