FoxhoundOp
- Apr 26, 2003
the Windows 7 beta can run on my Athlon XP 2500 @ 2GHz with 1.5GB, a Radeon 9600 XT on an 80 GB 7200 RPM HDD but Vista would be as slow as molasses?
You'd probably be able to run either OS on specs like that...
But you wouldn't have all the bells and whistles
It would look like glorified Win 2000 with more menus in the start menu.
That's odd, My sister's Sempron 2300+ Vista install looks like ... well, Vista.
The athlon mahcine should run Vista just fine, but it won't be able to handle aero. My laptops got a 1.8ghz intel processor with 1GB of RAM and it runs Vista without any problems. The video card you've got is probably even better than whats in my laptop, too.
Probably because Vista is installed on it.
You said it's look like a glorified Win2000, I assume you meant it would default to the "Classic" theme.
Perhaps I am buying into the FUD a bit. I admittedly haven't had a chance to run Vista on this hardware but I am using Windows 7 atm. Other than a BSOD after installing the nForce2 audio drivers which worked perfectly after a restart, I haven't had any problems with it yet. It's feels just as "snappy" as Windows XP even with Aero on. I'd be a liar, though, if I said I thought that Vista would run just as well seeing as I've had performance issues with it on a much faster computer (Athlon x2 3800 w/ 2 gb ram).
Win7 is faster than Vista, but doesn't mean Vista is slow.
