CrashGawker
- May 30, 2002
God I hate Linux...ok so I'm trying to load the Nvidia drivers that I downloaded from Nvidia's website which came in the form of a .run file, which like everything ELSE in Linux, does diddly when you double click or otherwise execute it. (I'm running my TV on s-video because no other option functions and currently it only works in black and white) And of course progress is exceedingly slow because for whatever reason my mouse is invisible so I have to move it really slowly and wait for things I want to use to highlight. MAJOR pain in the ass. Anyhow I tried running it under KDE and it just opens in a text editor...useless.
So 20 minutes later I've figured out how to run it under Terminal only to discover you have to run it as ROOT...ok so I log in as root and run it again and it says I can't run it with my X Server running. Well an hour later I finally figure out how to get out of X Server only to be unable to access my DVD with the file on it! So I reboot into KDE and spend 15 minutes trying to copy the file to the hard drive (why does Linux not use drives like normal storage devices where you can see them and go IN them and put stuff where you want it?!) only to have it stall out in the copying process several times and when it finally DOES copy I go back to command line.
Tried to run it and now it says some kind of checksum doesn't check out and it won't run. Is there ANY way to install this shit without having to program it in one bit at a time?!?!
