D-link Action
you can also look for the USB dongle, if you prefer a quick fix to wireless access.
What kind of set up are you looking for exactly? Also, you're network is 802.11g right? or are you going the N route?
802.11g was the wireless G networking, now the fad of wireless N routers are coming out. The data rate is 2 streams as opposed to one, so it rests at 300 Mbit/s and the range is increased as well, I believe 70 m...all this is still subject to have bugs and what not, and the final announcement should be around Dec 2009 for consumers to be using the technology regularly.
I thought you may jump the gun and buy the Pre-N routers, and go high-fi.
Any card will more or less work, you know what they say, if it aint broke, dont 'fix' it. If you get good range with those cards, just keep using them...you can always save money when building a new system
I've always had really good results with the LINKSYS WMP54G wireless cards. I've had 3 of them on different computers I've built and they never gave me a problem. worked just fine with 64bit OS as well.
For ram and motherboard, what are you going for? (do you want to do Crossfire in the future? How much overclocking do you want to do?) For the Q6600, if you are overclockng a lot, you might want something like DDR2-1000 or 1066 ram, however, you can probably get away with a good overclock and DDR2-800 ram.
GIGABYTE GA-EP45-DS3R is a good affordable motherboard, so is the asus P5Q.
