Hey Guys,
Im running an OC'd (4,3ghz) I7-2600k and 16gb of ram. My video card fried and a need a replacement for my GTX 580 OC.
I am thinking about either a GTX 1060 6gb or a GTX 1070. Would either card get bottle-necked by my system?
Rock that Sandy Bridge.
You'll probably be good 'till Cannonlake.
More likely Coffee Lake or Ice Lake and Cannonlake might be mobile only.
Coffee Lake actually uses Cannon Lake cores. Tho Coffee Lake is 14nm+.
Sigh, that's not how it works. He has 8 threads and games rarely use over 4 so he could be completely CPU limited even using just 50% of the CPU in most games. Hell in an older game like Fallout New Vegas he would be CPU limited even only using around 25 or 30% as that game only uses 2 cores and those 2 cores need to be extremely fast. Bottom line is looking at CPU usage is not the way to determine if the CPU is the ultimate limitation. Now of course if the CPU is at 100% then yes it is the limitation but again that's not really going to happen in any game if you are using a CPU with 8 threads.See: Intel & AMD Processor Hierarchy - 3rd gen and later i7s are a step above 1st and 2nd gen.
If your CPU usage is at 100% then it is the bottleneck.
I have an i5 2500K @ 4.6 Ghz and an overclocked GTX 1070. The only games in which I've seen CPU utilization reach 100% is Witcher 3 (only in Novigrad), and intermittently in Assassin's Creed Syndicate. Oh, also, Arma 3 - which is so CPU-dependent that I don't notice any FPS increase from my 1070 over my R9 280X.
Other than those, I haven' noticed a bottleneck from the GPU. If there is one, it's going to be pretty minor, except in the case of select games. Even in Witcher 3, Novigrad, the CPU only goes to 100% in some places, and even then, my FPS are about as good as non-bottlenecked systems with a 1070.
I posted a bunch of Afterburner graph pics in a thread somewhere, displaying my GPU and CPU utilization. I can't look for it right now, because the forums search is disabled.
Hey Guys,
