AntiSocialMunky
- Nov 4, 2006
So I put together a SCII gaming rig for a friend:
1) A10-5800K
2) That FM2 ITX board that catches on fire. (Went through only 1 DOA , didn't catch on fire but probably had a bad bios flash)
3) G.Skill 2133mhz Ram @ 1.6v
4) CD/DVD Writer
5) Intel 240GB SSD
Only problem is that I bought this case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811190113
Which comes with a 150W Propriety PSU that is some licensed version of http://www.zylax.com.au/aywun-dsp15...-150w-real-power-200w-peak-power-p-30686.html that has a tiny fan and is literally as far away from the case fan as possible.
I hooked everything together and it acted perfectly fine. It seems to boot/handle prime95 and play Starcraft || maxed (yeah, I didn't quite believe it) on a 1080p screen.
So the question is, should I switch out the PSU? So far the build has cost me $450 and my friend wants to try and keep it under $500. In addition any new PSU will need to be zip tied in because of the propriety PSU design. The PSU I'm considering is an 80 Bronze certified 300watt Athen Power PSU and $80.
Also HSF recommendations would be appreciated. The AMD stock heatsink just plain sucks and is noisy.
1) A10-5800K
4) CD/DVD Writer
5) Intel 240GB SSD
