Okay, i'm not sure why this is happening, but if i try to add a drive to my windows system, it won't automatically add a drive letter, but it will add a drive letter to my usb sticks and external usb drives without issue. It's just when I plug it into sata that it goes all wonky. I can see the internal HDD in disk management as a disk, but windows disk management refuses in any way shape or form to add a drive letter to it, even using diskpart with automount enabled. This is the error I get when I try:
"The operation failed to complete because the Disk Management console view is not up-to-date. Refresh the view by using the refresh task. If the problem persists close the Disk Management console, then restart Disk Management or restart the computer."
Absolutely nothing works. I've tried Diskpart, acronis, AOMEI, EausUS, chkdsk, sfc /scannow, microsoft fixit. Nothing works to get disk management to add a drive letter to an internal HDD. Like I said, USB disks and sticks are no problem. I've looked all over google and i haven't seen a single solution to this problem short of a total wipe and start over and at this point I'm not about to do that with everything I have installed and would have to reinstall.
I have other systems that do not have this issue. Just this one windows 7 x64 install. Can anyone shed light on why this error is occurring and how to fix it or if there is even a fix for it.
Thank you.
Thank you.
