I'm trying out W8 on my Fiancé's old HP laptop, I installed 64 bit, but i'm wondering if I should try it with 32 bit.
The laptop only has 2GB of memory and isn't likely to ever be upgraded beyond that. 64 seems to work pretty well, but are there any advantages over 32 other than the memory limit?
I need to wipe it and re-install it again anyway, with the lower requirements of 32 bit, would it work any better with such a small amount of system RAM?
Anyone compared the two? Suggestions? Comments?
