Well, my dad is in a bit of a bind right now. He changed logging on to NTDOMAIN to logging on to a WORKGROUP. He restarted like it asked him to and then when the login screen comes up, he types in the password that he used from NTDOMAIN and it does not work. He says he has never set another password. Guest account is disabled and the Administrator account must not be set. So now all he can do is sit at the Windows screen. Reformating the computer is not an option. How can I either get past this screen or change it to log back in thru NTDOMAIN so his old password will work?
Thanks A Bunch,
Will
Thanks A Bunch,
Will
