Originally posted by AceTKK
When I open the processes tab, I have 4 seperate instances of svchost.exe running. Is this normal, or is it an indicator that I'm infected with something? One of them uses 20,000+ K and the rest are under 5,000.
Thanks,
-Ace-
Originally posted by Ranma_Sao
Disabling services is silly.
Please don't tell me you know how to get through it. I get really sick of the prolific bullshit around here. ICF is just as safe as ZoneAlarm. The only better thing is to have a NAT firewalled between you and the internet.ICF != security.
Originally posted by GreNME
Disabling services has never been proven to provide any performance increase at all. It's total bullshit.
As for "security risks," all you need to do is turn on ICF. Presto! No security risks. Running any machine on the net without a firewall is Russian roulette.
Prior to SP2, the ICF only for incomming connections yes. Starting with SP2 the firewall wall was reworked for incomming and outgoing connections. Yes, prior to SP2, a third party solution would be needed to monitor\block outgoing connections.Originally posted by E-virus
I thought ICF only detected risks coming from the outside, not inside going out. That is why a better brand firewall is a better choice.
In addition, how often do you think Microsoft improved ICF over the years. Enough said.
Even hardware firewalls don't detect unauthorized internet usage from the client's side. So, I personally run both, a hardware firewall (Netgear FWG114P) and a software one (Sygate).
Originally posted by Iclisx
Remote Registry (CLIP)
Your point is valid since if I was an administrator, I would just net use \\targetmachine\c$ and regedit load the hive I wanted to edit.
thats a bad idea if your running in a domain.Originally posted by shade91
Keep in mind I can also unshare that c$ share via the registry as well as those other various hidden shares. No, they won't come back on a reboot if you unshare them by the registry.
