I am trying to connect two wireless pci cards in ad hoc mode, so that I can use the internet on my other computer without having to buy a router. However, the cards can see each other and seem to connect ok, but the computer in the other room that does not have internet is not able to obtain an ip address all the time. Sometimes it will obtain an ip, but the ip of the gateway computer with internet doesn't show up and I can't use the net.
But every once and a while, they will seem to work and be fine for a few hours, but then the connection will like go dead, it still says its connected, but they dont talk back and forth. I've messed around with ipconfig, trying to /release /renew, but I get an error back saying that it couldnt resolve the the DHCP server.
I've also given both computers static ips and defined the gateway on the other comp. This seemed to work for a little bit, but then just stopped working and I havent been able to reconnect properly again.
Also, when they are connected, I can access all the files on the no internet comp, but not vice versa. I am using administrator on both comps and have configured the share rights properly I believe, allowing everyone access, but still no go.
The two cards I'm using are a US robotics turbo PCI 802.11g and an xterasys pci 802.11b. Could the two different cards have anything to do with it?
Any help would be appreciated.
edit. forgot to mention that I have also disabled WZC and I get a better chance of connecting, but still nothing solid.
