Hi everyone,
On Monday, I was called to my cousin's house to set up his wireless network. He uses Verizon DSL and has a Dell wireless router. I set up the network and everything worked fine.
I then added a Linksys wireless card to his PC a room over, as requested. Computer A, which is connected through a wired connection to the router, works fine. Computer B, his in the other room, does not. Computer B detects a very low-strength signal, but even when detecting the signal at "good" quality, it will not resolve hosts. After restarting and releasing/renewing IP addresses, it still did not work.
I checked IPConfig and it cannot find a DHCP server or default gateway, but is assigned an IP address. The router is set to automatically assign a DHCP server to the computers on the network.
After I left, a laptop tried to connect to the network and had no problems, so the router is properly set up.
Any ideas? I'd like to go back tomorrow to fix it, so if you can get back to me before then, I'd appreciate it immensely.
Thanks!
Thanks!
