liquidtrance123
- Aug 29, 2000
Anyone know of a good set of Wireless Home Security Cameras that work with mac? Basically if they're wireless once they're setup i should be able to use them on any system correct?
liquidtrance123 said:Anyone know of a good set of Wireless Home Security Cameras that work with mac? Basically if they're wireless once they're setup i should be able to use them on any system correct?
even if my wireless router has a WEP on it?KaosDG said:the motorola's are nice.
A firewall would take care of it, just some people tend to plug them in and just go.
"Set it and forget it" -Ron Popeil
If it's wireless you also have to consider someone sniffing the packets
