PornoSatan
- Sep 3, 2004
Any potential issues to speak of?
The only potential issue I see is related to ghosting since I doubt that most wireless KBs have NKRO, other than that it might take a few extra ms to display what you type because they're likely to use usb and have a low polling rate to save battery life. The ghosting issue has to do with how most KBs without NKRO process key presses and use the same circuit for multiple keys so if you press two keys too closely together it might disregard one of them or switch the order if the second one pressed has a shorter path to the part of the KB that processes KB presses.
Sometimes, I notice some bunching of letters if I'm typing really fast on my wireless keyboard, but they always sort out correctly a second or two later.
Just have to say, PornoSatan is the best name I've ever seen here on [H]!!
