well let me just show you the diagram of the actuall thing i have setup...
The problem i have are with the 2 computers (running xp pro)
I would like for them to get their internet connection from the the wireless access point in the office were these computers are located. The problem is with the conflicting wired network that shares the printer and files between the 2 computers.
In order to be able to go online through the wireless AP i need to disable the NIC, if i need to print something or share some files i need to disable the wireless card.
The only time ive noticed the internet work was when i disabled DHCP on the linksys router but then i still cant print. any tips?
im really frustrated btw
THANKS!!
THANKS!!
