not exactly sure what you are asking
If anything get some more system ram, go up to 4gb.
Info in Sig.
1680x1050
Might go 1920x1080 soon tho.
i7 920/930 worth the $$ over 965? PC will last me 2yrs
that being said this is what I would do
I would recycle your current setup, maybe save the 8800GT, they are decent and will play WoW just fine... this is what you should get
CPU and ram combo:
Phenom II x4 940 Black OEM
2 x 2GB Geil DDR3 1333
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.419909
I dont know what motherboard you have, that processor I listed might work in your board
Motherboard:
MSI 870-G45
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130290
that comes to around $300
if you can afford a little more I would get this as well:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814103086
CPU is AM2+, won't worry sorry, plus its OEM.
Am I the only one who hates the term "lag" when used to describe low framerate?
Unless he's actually talking about network lag in which case I don't think a new computer would be called for.
Turn down view distance unless you have 3.4 ghz.
Tested it to death, thats the frequency wow likes at ultra. Otherwise you'll be beating the crap outta your videocard.
funny my wifes rig works great at full settings and modded for higher than full settings...
she only has a little q8200 @ 3.15GHz
I can tell you that my Phenom II x4 965 @ 3.4GHz is way faster than my old q6600 at the same speed...
my q6600 @ 3.0 is faster than my wifes q8200 @ 3.15Gz...
and my old q9550 @ was faster at stock than my wifes q8200 was @ 3.15GHz...
I dont know who made up this magic 3.4GHz number... if that was the case then my old Celeron (Prescott) @ 4.0GHz would rape WoW... but it was slow as a snail...
it all comes down to a CPU's ability to crunch numbers...
The new WoW patch also did a complete overhaul on the chat system. If you're running chat addons that are out of date it will really gimp your framerate and even cause loss of video and UI in high traffic areas like Dalaran.
Problem with WoW is it's not optimized very well. You think a game that uses super low graphics and many many less polygons than current games would be running at 100 to 200fps at all times. I just hope their next MMO makes much better use of CPU. Even my system can get down to 30fps in certain raids. Even before the patch dalaran could still push my fps down to 30. This is with all settings on max.
There is a bug in the game where it will keep using more memory until it hits the 2GB 32bit memory limit. This mostly happens in Dalaran, but people been saying it happens elsewhere as well.
They should pay iD a few million to take a look at their stuff as a consultation :-P
God knows they have the money.
WoW runs good with a SSD, that may fix your problem.
