What I don't understand about the above 3, is that if/when there was a problem, how would you troubleshoot it? It was take days, no?
Nah, just put in a new cable. D'oh
Those floors that you can put cables under are the best!
Shoot, If I would know any better I'd say someone just staged those pictures. I can't believe ANYONE would not only do that, but the senior (non-IT/IS) management would let it get away like that.
My question is how do the floors get cleaned? I'd imaging your cleaning crew (The ones authorized for server room access) do it by hand?raised floor is pretty common...cable tray underneath is as well, especially in older sites. Back in the dino mainframe days...you didn't run your cables overhead. Today's mainframes are easier on the cabling...at least as far as what we run.
Heck I think it'd take a day just to UNHOOK all that stuff and untangle it.Man, it would take at least the better part of a day at the absolute minimum to set something like that yellow monstrosity up.
There are two ways. There are companies out there that do nothing more than DC cleaning and stuff like floor sealants for bare concrete. Last time we used one, they shut down a major database server and shutdown a critical piece of my companies work for 4hrs. We kicked them out on the spot.My question is how do the floors get cleaned? I'd imaging your cleaning crew (The ones authorized for server room access) do it by hand?
Yea, I'd never trust anything like that to a third-party unless I'm there. And if I'm there, I may as well be doing it myself.Last time we used one, they shut down a major database server and shutdown a critical piece of my companies work for 4hrs. We kicked them out on the spot.
I'm talking more about the mopping, stuff like that that has chemicals that could seep under the floor.You can also go out and purchase the vacuums w/ special filters (not just a shop-vac) they use and do it yourself. We schedule a few weekends and vacuum a section by hand.
It still looks pretty shitty, but I think some of these are far worse....
http://www.geeksaresexy.net/wp-content/uploads/2007/07/wrong4.jpg[IMG]
[IMG]http://farm3.static.flickr.com/2277/2180039413_f54b142ff4_o.jpg[IMG]
[IMG]http://www.datacenterknowledge.com/wp-content/uploads/images/cxtecwinner.jpg[IMG]
Even better...
[URL="http://www.geekabout.com/2008-02-19-479/40-most-disastrous-cable-messes.html"]40 Most Disastrous Cable Messes[/URL][/QUOTE]
Holyyy.... :eek:
[quote="450, post: 1033317630"]What I don't understand about the above 3, is that if/when there was a problem, how would you troubleshoot it? It was take days, no?[/QUOTE]
Fire...
...and lots of it.
I was thinking more in-house cleaning person, not sure how EVERYONE out there does it but if you have a particular person you trust to do it?
I don't see an issue with vacuuming.
My question is how do the floors get cleaned? I'd imaging your cleaning crew (The ones authorized for server room access) do it by hand?.
From my experience in seeing some horrific setups..."They don't clean it"...period...ever....
I'll never understand why a company will hire an outside firm to do something that its employees are willing to do. Even if you have to pay them overtime its usually still far less expensive.
this is how I patch.
I don't see any labels... except for a single cable.
So, there is a bit of an update to the story behind the crazy cable mess. I heard from our Director of Security that there were some IT people from the corporate headquarters coming in to fix all the cabling issues. My first thought was "What did they do so horribly, horribly wrong to deserve that particular task?" and the second was "I should look and see how they did, so I can take more pictures." So, I wandered in there a few days after they had been in there, and they had done 2 things:
1. Put a stand fan blowing onto the 4 servers that are in there.
2. Move one of the servers OUTSIDE the server room onto a table in the front office.
That's it. Maybe they took one look at the cabling and just said fuck it.
I'd burn it with fire
Then I'd rebuild it
