Back in the WHS v1 days, built a WHS around a Norco 4020. I ended up only using half the bays, but I ended up switching to a couple Synology when MS retired WHS. The Norco was passed on to a friend who used it until recently, and is now back in my possession. The only thing that I ever swapped on the unit was the fan wall which the 4x80mm was replaced with a 3x120mm, forget which fans, that someone was machining and selling back when the case first came out. I probably found the guy on here or one of the home server forums.
I need to build a new Plex server, probably running Win 10 with Drivepool and maybe Snapraid, that also does some other tasks so I was debating on trying to fix up the Norco. I just don't know if it is worth trying to use the Norco though since I am not sure what I need to do to bring it up to date.
I know the old card I have won't work well since it is the SASLP-MV8 so only Sata 1. I wasn't sure if the backplanes matter though in the Norco. I can't seem to dig up anything either way whether they need to be upgraded.
Any suggestions are appreciated.
UPDATE 1
I have decided to shift my gaming PC into the Norco and build a new gaming rig. I still have a few things that need to be address in my Norco though.
The PC:
i7-4770K
Asus Z87-Pro
16GB DDR3 1866
FirePower Silencer MK III 750W 80Plus Gold
The Norco has SAS backplanes and as mentioned I have the AOC-SASLP-MV8 which still needs replacing. I figure I will use a SATA to SAS reverse breakout cable for the first 4 bays fed off my mobo.
The 120 MM fans are Scythe Slipstream 120mm 1200 RPM.
I am wondering if while I have the fan wall out I should replace the fans. I believe they work fine, but I am just thinking while I have the wall out it would the easiest time to upgrade them.
UPDATE 1
The PC:
i7-4770K
Asus Z87-Pro
16GB DDR3 1866
