Yeah, so I play WoW.
It's by no means the only thing I play, but it probably takes up about half my gaming time.
Not that long a go I upgraded my PC, I had been running a gtx 260(192), and I stepped up to a gtx295.
I was happy with the gtx295 for most things, but I found it disappointing in WoW.
Basically the sli didn't work, I got exactly the same fps as I did with the 260 (half a 295 or thereabouts), some quick research showed that this problem was pretty well known, and because of the tiny minority of sli users playing WoW, no one was looking to fix it.
It didn't bother me much, after all, even a 260 is more than enough to get great performance out of WoW, but it was still a minor annoyance.
Until today, when I found that simply unchecking the "reduce input lag" checkbox fixed it, fps just went through the roof and pretty much stayed there.
I don't know what "reduce input lag" is supposed to do, I played for a while with it on and with it off and could perceive no difference in the relative lagginess of any inputs at all, so it appears that it's sole purpose is to screw with me.
So yeah, if your sli setup seems uncharacteristically sluggish in WoW, try turning off "Reduce input lag".
The new shadows still take a big, big chunk out of performance at the higher settings though....
