Could some post a pic of where on the WRT54G v2 PCB I can solder fan leads to? I am hoping for a voltage of 7V to 11V, and a current of no more than 0.2A.
Current doesn't matter. The fan will only draw what it needs to draw. Well, I shouldn't say current doesn't matter. It needs to be able to provide at least what the fan needs to draw. It could provide 200 amps, but if the fan only needs .2 amps then that is all it will draw. Anyway, your best bet is around the power input. I don't know what the input voltage of that particular device is, but it is probably around the range you are looking for. Just get your multimeter and start probing.
