achensherd
- Nov 2, 2007
I recently got a Creative X-Fi XtremeMusic, installed the drivers from the CD, and applied the 10/06 patch (I'm on XP 32-bit). Everything is working fine, with the only "abnormal" incident being hearing persistent static, created after changing the mode while my media player was still running (another mode change made it disappear).
The problem I have is that the volume, bass, treble, line-in, mic, etc. settings keep reverting back to default every time I change the mode or restart my computer. Sometimes it's just the volume setting (it seems to like 45% a lot), but a system restart pretty much guarantees everything reverts back to default.
I doubt I'm the only one to encounter this, and made a few searches before posting a new thread, but couldn't find anything. Has anyone else encountered this issue? If so, what did you do to fix it? Is there some hidden setting that I don't know about somewhere?
Thanks.
Thanks.
