Nov 18, 2005 #1 C CRaZYMoFo Limp Gawd Joined Jun 18, 2005 Messages 489 Im running an AMD x2 3800+ and would like to OC it soon. It is an ADA3800DAA5CD CCBWE 0535SPMW 1321069I50521 I would just like to know what kind of clocks and voltages ppl are using to OC. Info would be a great help. Thanks in advance.
Nov 18, 2005 #2 G Gronich13 n00b Joined Oct 10, 2005 Messages 22 What heatsink will you be using? Use a max voltage of 1.55v (preferably 1.5v) and you should reach between 2.4 and 2.8Ghz.
Nov 18, 2005 #3 C CRaZYMoFo Limp Gawd Joined Jun 18, 2005 Messages 489 Im running a Zalman 7000B-Cu (was going sff and bought cooler before i switched back to atx) Hopefully will get a SI-120 as soon as I have the $$.
Nov 18, 2005 #4 J Jiggaman2576 Limp Gawd Joined Oct 27, 2004 Messages 377 I have a 3800+ on water running 1.49 volts @ 2.7ghz on each core. If I my load temps only reach 100F, can I up the voltage higher and try for more or would I start risking my CPU's health?
