BillParrish
- Aug 25, 2006
For those of us that can read.
http://www.intel.com/products/chipsets/X38/index.htm
Some clues as to what the issue that delayed release:
Problem:
That first one is probally not a big deal as we will be putting 16x video cards in 99% of the time. The second one probally resulted in several large piles of worthless PCBs, ouch.
1. PCIe 1.1 cards in PCIe slots off the MCH lead to boot failures.
Problem:
The Intel® X38 Express Chipset sets the TS1 Ordered Set - Symbol 4 Bit[6] to 1b when
a PCIe 1.1 card is plugged in. This is a reserved bit which is used in PCIe 2.0 to
broadcast support for selectable de-emphasis. PCIe 1.1 Specification states that Bit[6]
should be set to 0b. With some 2.5 GT/s PCIe 1.1 I/O cards of widths x8/x4/x1, system
restarts and hangs were exhibited during PCIe link initialization when populated in MCH
slots.
Implication:
slots.
Implication:
System unable to train some 2.5 GT/s PCIe 1.1 cards that don't comply with the PCIe
1.1 Specification. Failures have occurred across multiple vendors and different types of
PCIe 1.1 cards.
Workaround:
Workaround:
Contact your Intel field representative for the latest BIOS information. Modification to
the Link Stability/Recovery Algorithm will fix this issue when using non-compliant cards
but customers should continue working with their card vendors for PCIe 1.1 Spec
compliancy.
Status:
compliancy.
Status:
No Fix. For affected steppings, see the Summary Table of Changes.
2. Intermittent IERR# hangs during cold boot does not detect PCIe
cards.
Problem:
Problem:
During cold boots, the MCH may hang during power-on and assert IERR or may not
detect PCIe cards off the primary port or secondary port. The 1.8V on-die voltage
regulator which powers the PCIe & DMI PLL may not be stable when powering on,
causing above issues.
Implication:
Implication:
PLL not operating correctly could result in not detecting PCIe cards or DMI may not
operate correctly, resulting in system hang and IERR# assertion.
Workaround:
Motherboard designers are required to implement board changes:
• Require 1.25V through LC filter on MCH VCCAPLL_EXT (Ball A20) & VCCAPLL_EXT2
(Ball AR10).
• Require 1.25V on MCH VCC_EXP_PLL (Ball AB13).
• BIOS must disable 1.8V on-die VR. Contact your Intel field representative for the
Status:
Status:
