I have a Sapphire X800XT PE I have been having a lot of trouble with. I have had intermittent crashes and visual artifacts in games. Once I even had the card seemingly "shut off" during normal windows use, my monitor just stopped getting a signal. I suspect it may be overheating. I've seen it 80C+ from heavy gaming. The fan makes some bad noise when I first boot up. I even added a "slot blower" type cooler right next to the card but temps still don't look great.
Anyways I have contacted Sapphire support and my general impression is that they are ignoring me and they won't provide me with an RMA. Furthermore, all the information I can find says that it takes 4+ weeks for them to "process" an RMA because they send the cards back to China. If they are that slow, I would have to buy a new card(which I can't really afford). I'm never buying Sapphire again.
So I am thinking if it's just a cooling problem I would be better off fixing it myself. If the card later died... Would it be apparent if the cooler had been removed, new thermal compound applied and if I had cleaned and oiled the fan? I never mess with my video coolers at all.
