I have a Xbox 360 Elite and it is hooked up to my Westinghouse 37" 37w3 monitor via component cables.
I was playing Mass Effect last night and after finishing a long run, I turned my console off. When I started the console up again, I noticed the XBOX boot screen was REALLY faded and washed out. When Mass Effect loaded, it also seemed to effect the Microsoft splash screen at the beginning of the game.
I turned the system off and on again to see if it was a glitch. The same thing appeared. I opened the Xbox dashboard and noticed that it was also affected with the problem. I loaded up Halo 3 to make sure I was not just losing my sight and any map with white snow looked completely horrible.
I changed to the other Component ports on the monitor and the same thing happened. Anyone had this issue? I'm about to get a HDMI cable just to test it to make sure it isn't the cables or my monitor.
Just hoping someone's seen this problem before.
Daines1
Daines1
