The Hunter
- May 29, 2002
I've got a few questions regarding the upgrade versions of XP Pro (as in, not the full version). First of all, can you do a clean install, or does it have to be on top of an existing install? Secondly, what is required to install the upgrade? Do you just give it a CD key for a supported previous version?
My specific situation is this: I'm going to buy a laptop from Dell, and it's cheaper for me to get XP pro from my university than to get it installed on the laptop. I also want to have a plain copy of the OS (not the garbage restore disks that put all the Dell crap back on). So, is it possible for me to do a clean install on that laptop if I just have the CD key and whatever stupid restore disk they give me?
Also, does anyone know if the windows versions that MS sells to universities for students are normal retail versions, or are they the OEM ones without activation, etc.?
